How to get DOPs to transform your input point vectors?
magneto
it happens automatically according to attribute qualifier (attrib type info), the same way as Transform SOP does that
so like 3 float [3f] or color [3fc] attribute will not be transformed
but vector [3fv] or normal [3fn] will, similarly transform matrix [16fx] or quaternion [4fq] etc.
Edited by anim
Thanks anim, I understand now :) Do you know if it matters if a vector attribute is normal vs vector? Because some attributes show up as vector, and some show up as normal.
I know how to set these up when I create the attribute but I am not sure if I can change the qualifier. I assume I can just create a new Attribute Create with the same attribute name, where I specify the qualifier but disable Write Values.
