magneto Posted October 8, 2015 Share Posted October 8, 2015 Hi, If you want to an object being eaten away, or rotting, etc. I thought I could merge/mix volumes but I don't know how to create the pattern that will grow over time and look random. Is there a better way? Should I be using particles instead or in addition? Thanks Quote Link to comment Share on other sites More sharing options...
Farmfield Posted October 8, 2015 Share Posted October 8, 2015 I played around with the SOP solver using noise in VOP's to drive negative displacement and then remeshing as it pipes out, onto the next frame as it rinses and repeats... If you want to have more control, you'd just create a texture in comp to (or COP's, for those who uses those) and drive the erosion with that. And you can of course use this in the other direction, growing stuff like mold like structures... 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted October 8, 2015 Author Share Posted October 8, 2015 Thanks I can see that being useful Do you remesh the geometry using volume tools? I am wondering about cases where the geometry entirely disappears. Quote Link to comment Share on other sites More sharing options...
Farmfield Posted October 8, 2015 Share Posted October 8, 2015 For the basic setups I did, no, I just used the remesh node. The downside of keeping it as a mesh is when you will come to the point where the negative displacement goes into negative values and starts doing funky stuff - unless you handle this in VOP's, setting it up so it can't go beyond that point. And setting up the mesh being eaten away as in deleting points/polys, well, you'd do that in SOP's, use the clip node, delete points by boundary, whatever works for what you want. Using volumes you won't run into the issue with mesh reversal, but doing high res volume operations in a solver will of course be pretty darned computationally expensive - add to that the per frame meshing - but handling it as mesh can be expensive too, keeping the mesh dense enough for the remeshing not to create noticeable flickering, etc... You just gotta play around and see what works... 1 Quote Link to comment Share on other sites More sharing options...
gpapaioa Posted January 12, 2016 Share Posted January 12, 2016 Greetings guys. Any simple setups will be highly appreciated. Tryting to create an erosion effect for the first time: pieces of geometry fall and erode to particles Quote Link to comment Share on other sites More sharing options...
loudsubs Posted January 13, 2016 Share Posted January 13, 2016 I did some erosion experiments a while back using VDB's. I'm not sure where the hip file is, but the overall workflow was to use particles converted to VDB, and then use the VDB combine in a solver node to subtract away at the collision SDF each frame. Then mesh it with VDB convert. It worked fairly well on a basic box. I liked the volume approach because the polygons don't get stretched as the erosion happens. Quote Link to comment Share on other sites More sharing options...
Jordan Walsh Posted January 13, 2016 Share Posted January 13, 2016 I saw this vid the other day... pretty cool stuff. Done with VDBs Quote Link to comment Share on other sites More sharing options...
gpapaioa Posted January 13, 2016 Share Posted January 13, 2016 My lack of knowledge concentrates on how to setup the SOP solver Quote Link to comment Share on other sites More sharing options...
Dave Stewart Posted January 18, 2016 Share Posted January 18, 2016 Hi guys! I put together a quick and dirty .hip file showing the basic erode setup I used for the video Jordan posted. Let me know if it makes sense, or if there are improvements that could be made... --Dave DJS_FLIP_VDB_FluidErodeSetup_02.hip 2 Quote Link to comment Share on other sites More sharing options...
gpapaioa Posted January 18, 2016 Share Posted January 18, 2016 Thank you very much Dave. Quote Link to comment Share on other sites More sharing options...
Dave Stewart Posted January 21, 2016 Share Posted January 21, 2016 Glad to help Georgios! Quote Link to comment Share on other sites More sharing options...
