Rename volume field
gpapaioa
I tried Name SOP and it gives me a no name field for some reason, lets try the others..
if you are use Rename section of the Name SOP
make sure you clear Number of Namings parm as that possibly is resetting your names to nothing and rename then doesn't find the name you want to change
