rendering from the windows command line with a batch file
Hi there,
I am working on a school project and am trying to figure out houdini's command line rendering.
When I work in maya I usually write .bat files that launch maya's batch render with specified parameters.
I can't get houdini's to work for some reason.
SET hscriptDir="C:/Program Files/Side Effects Software/Houdini 14.0.444/bin/"
cd /d %hscriptDir%
SET hip_file="Z:/render_rnd.hipnc"
SET rop_path=obj/ropnet1/mantra1
SET startFrame=1
SET endFrame=1
SET savePath=$HIP/render/test_$F4.exr
hbatch %hip_file%
render -V -f %startFrame% %endFrame% -o %savePath% %rop_path%
Ideally I would like to be able to open this bat file, change the frame range / mantra node and just run it. At the moment it won't read any commands after hbatch reads my hip file which makes sense since it's an executable but is there a way to also pass my render command to hbatch? If I run the code in a command prompt line by line it works.
Thanks for looking
-David
The typical way of doing this is to write out an archive for the renderer, in this case an IFD file for Mantra from the Mantra ROP. Then pass the IFD file directly to Mantra at the command line.
http://www.sidefx.com/docs/houdini15.0/render/batch
This is because renderer licenses are usually less expensive than full 3D package licenses. What Jason posted works too. If you use that method and if you have time later come back to it and figure out the IFD workflow too. It'll come in handy later.
  • 4 months later...
I encountered the same problem. You have to use the echo command without quotation marks. Hbatch also struggled to use the $HIP variable. Loading the files via the mread command fixed this issue. It is also very important to use forward slashes.
The working .bat file looks like this:
SET hbatchDir="C:\Program Files\Side Effects Software\Houdini 15.0.347\bin\"
SET hipFile=c:/myProject/myHoudiniFile_1.hip
SET ropPath=out/mantra1
SET startFrame=1
SET endFrame=100
CD /d %hbatchDir%
(ECHO mread %hipFile%
ECHO render -V -f %startFrame% %endFrame% %ropPath%) | hbatch
PAUSE
To render .ifd Files this .bat script works.
SET folderPath=c:/myProject/
SET fileName=myIfdFile_
SET startFrame=1
SET endFrame=100
CD /d %hbatchDir%
FOR /L %%A IN (%startFrame%,1,%endFrame%) DO (
  mantra -f %folderPath%%fileName%%%A.ifd
PAUSE
Edited by AlSk
