Dust Storm - particles driving clouds?
cwalrus
Hi - i'm following an outdated tutorial (houdini 12 i think) on CMIVFX, and i'm stuck trying to get my particle sim to drive the velocity on my clouds. Their method doesn't work anymore with H14.
Any help? Basically I just want the particles to drive the velocity on billowy smoke. File is attached.
THanks!!!
cameron
DustStorm03.hipnc.zip
Hey so I didn't have a lot of time to look at your hip file, but quickly built an example instead hope it helps. Basically the VDB from particles is set to velocity trail and I use it to create a VDB from the point attribute V so it gets picked up in the source volume!
The hip file explains it better :)
velocity_from_particles.hipnc
The fluid source node creates the volumes needed for the fluid sim. I don't think you can just plug the sphere directly into the Source Volume DOP node as there'd be no fields for it to work with.
http://www.sidefx.com/docs/houdini15.0/nodes/sop/fluidsource
http://www.sidefx.com/docs/houdini15.0/nodes/dop/sourcevolume
If you use the billowy smoke shelf tool on a sphere for example you'll see it creates the same setup.
Edited by carlo_c
