gpapaioa Posted October 25, 2015 Share Posted October 25, 2015 Hello. I cant seem to find enough resources on the forum about the Gas Repeat Solver. Can someone help me understand how to use it and which is the correct setup to retime (slow down) a Pyro simulation. Thanx. Quote Link to comment Share on other sites More sharing options...
anim Posted October 25, 2015 Share Posted October 25, 2015 Where did you get the idea that it can be used to slow down your sim? if anything it can speed it up as it will repeat some operations without adjusting the timestep so if you apply that to advection for example you will advance more steps within one timestep but for retiming the smoke/pyro sim for you can use Gas Upres DOP node, have a look at UpresRetime example in help Quote Link to comment Share on other sites More sharing options...
gpapaioa Posted October 25, 2015 Author Share Posted October 25, 2015 Thank you for that short but very explanatory answer. Cause all I have been managed to achieve is to speed up the sim. I read that it can be re-timed in general (speed up/down) from this thread: http://forums.odforce.net/topic/15050-power-of-gas-repeat-solver/ Didn't get great results with the Gas Upres DOP or the Time Scale in the Pyro DOP but will try more. Thank you. Quote Link to comment Share on other sites More sharing options...
ranxerox Posted October 29, 2015 Share Posted October 29, 2015 you could also try writing out subframes (using oversampling on the dopnet, and look up using $N on a geometry ROP), then playing back the subframes at normal speed. It does change the look of your sim somewhat, so it's not %100, but for a lot of sims you can work this way. -G Quote Link to comment Share on other sites More sharing options...
