How do i make pyro smoke expand quickly ?
ObiNon
You want expansion, also called divergence, also called gas released...
I think there is probably a way of doing it in the default pyro setup, look for something like "temperature influence gas", but it might be influence heat, in which case not what you want.
Add a gas calculate into the advect stage? Of the pyro solver and copy temperature field to divergence field. Not exactly what you want, but you'll see it start to do something. Really you'll want a vop or wrangle there, see if temperature exists (not zero) and then fit and flip the field. So temperature might be 0-10 range, fit that to 0-1 and complement it, then multiply by how much effect you want...
On mobile now, if that makes no sense I can help tomorrow.
Christian.
  • 4 months later...
