hair spray sim - tips&tricks
WLVL
Hello everyone!
I am trying to create an hairspray/aerosol sim.
I started with a particle sim for the fast ejected part. I then
use that as a source for a smoke sim.
i tried tons of different smoke shapes  but i can't achieve the result im looking for.
any idea on how to setup the smoke sim properly?
would you suggest another workflow?
any tip are much appreciated!
thank you in advance
reference [1-9 sec ]
problems:
-mushroom shape, if i get rid of it increasing dissipation, the smoke sim look just like the smoke source
-not getting that cone like spray smoke
aerosol_spray_particles_v01.mov
aerosol_spray_smokee_v01.mov
aerosol_spray_smokesource_v01.mov
aerosol_spray_v05_tips.hipnc
Can't this be done by using the particles as the "spray" itself and use an created attribute as temperature using a sphere or a generic volume to modify that attribute and then emit fire based on that temperature?
So in the end this could be a particle work+pyro work, I'm a noob so I'm jsut throwing an idea but I'm not entirely sure on how to practically approach this.
Cheers!
Cheers!
I think he mentioned making the effect that shows before the before, aka the misty advected bit.
