faxingberlin Posted November 4, 2015 Share Posted November 4, 2015 Hello.. Nowadays I study logic circuit. And.. It just exercises First, I want to create a half-adder in Houdini. There is XOR, AND, OR .. Vop node in Houdini! So, I try.. I don't know the output.. There is a simple Half-Adder I created.. (Link) http://www.neuroproductions.be/logic-lab/index.php?id=48109 Could anyone help me? please.. half_adder.hip Quote Link to comment Share on other sites More sharing options...
Skybar Posted November 4, 2015 Share Posted November 4, 2015 I did the same setup as in your link here, hope it helps: half_adder_dv.hipnc 1 Quote Link to comment Share on other sites More sharing options...
faxingberlin Posted November 4, 2015 Author Share Posted November 4, 2015 I did the same setup as in your link here, hope it helps: half_adder_dv.hipnc Wow.. Thank you!! It's helpful to create 4bit adder Quote Link to comment Share on other sites More sharing options...
faxingberlin Posted November 5, 2015 Author Share Posted November 5, 2015 I did the same setup as in your link here, hope it helps: half_adder_dv.hipnc I create 1bit full adder After I continue making 4bit adder. But I have a question. I replace mirror node to trans node, then it doesn't work.. What if I create 4 output(Sphere) Am I use more mirror node? Quote Link to comment Share on other sites More sharing options...
faxingberlin Posted November 5, 2015 Author Share Posted November 5, 2015 (edited) Wow.. Thank you!! It's helpful to create 4bit adder Finally I Finished! Thank you !! Edited November 5, 2015 by faxingberlin Quote Link to comment Share on other sites More sharing options...
