aoisaki Posted November 18, 2015 Share Posted November 18, 2015 I like this very much ! But i try for a long time I can't get same result Specially the smoke on the ground please help! Quote Link to comment Share on other sites More sharing options...
LaszloFX Posted November 18, 2015 Share Posted November 18, 2015 Hey,I'm sure there are many ways of doing this effect.But I quickly put together a scene file for you, in case you would like to look at my approach. Basically, I animated a polygon Circle object, gave it a Trail to Compute it's Velocity and used that as an emitter in the Pyro simulation. I also deleted the circle from the center, to stop the emission, but you can also deactivate it on your Source node. Also you can emit particles as well from the center and used that as a source emitter, just make sure that you have Stamp Points Method on your Fluid Source node under Scalar Volumes Tab. I hope this helps a little. Cheers, Laszlo shockWave_rnd_v001.hip 3 Quote Link to comment Share on other sites More sharing options...
aoisaki Posted November 18, 2015 Author Share Posted November 18, 2015 Hey, I'm sure there are many ways of doing this effect. But I quickly put together a scene file for you, in case you would like to look at my approach. Basically, I animated a polygon Circle object, gave it a Trail to Compute it's Velocity and used that as an emitter in the Pyro simulation. I also deleted the circle from the center, to stop the emission, but you can also deactivate it on your Source node. Also you can emit particles as well from the center and used that as a source emitter, just make sure that you have Stamp Points Method on your Fluid Source node under Scalar Volumes Tab. I hope this helps a little. Cheers, Laszlo Your set up is amazing! nice & clean to understand! Thank you very much ! Quote Link to comment Share on other sites More sharing options...
ParticleSkull Posted November 19, 2015 Share Posted November 19, 2015 Sorry for bugging here but thx for the setup, Laszlo. Quote Link to comment Share on other sites More sharing options...
LaszloFX Posted November 23, 2015 Share Posted November 23, 2015 Your Welcome! Enjoy! Quote Link to comment Share on other sites More sharing options...
lightmansor Posted November 23, 2015 Share Posted November 23, 2015 Laszlo, Fantastic your Reel! Very inspiring! Quote Link to comment Share on other sites More sharing options...
