Displace along normal using a texture in Houdini 15
Sidekick
Hello,
I'm missing something simple I'm sure but this has stumped me. Prior to Houdini 15 I've been using the same setup for a while to displace geometry with a texture map. The setup uses a vopsop and work exactly as expected. Upgrading to Houdini 15 and switching to a Attribute Vop the setup no longer works when using a texture. Displacing using procedural noise works the same as before. What am I missing?
Thanks
displace.hipnc
Hello,
Thanks
attachicon.gifdisplace.hipnc
The uv node is set to create vertex uv´s, but the attribute vop is set to run over points.
Edited by mawi
