flip+goal+collision... why is this happening?? whyyyy
dyei nightmare
i want a fluid colliding in a glass  then poured, then attracted by a goal, with fidelity,  but why is this happening??   it just disapears in the nothing  after pouring...    somebody knows??
pd. im in houdini 12.5
whytfthishappenswhyyy.hip
Edited by dyei nightmare
I think in order to transfer the goalPos attrib correctly you need the point count in the flip sim to match. I referenced the scatter node from your goalPos inside the fluid source to keep the point count the same. There was also a problem with the way the velocity is being added/multiplied inside your vop network. I changed this to mix between the two based on your key framed goalon attrib. I think you could do some work here to get more control.
Cheers,
WD
matchPointCount.hip
