fetch ( stamp ) object ID, used in chops
mirHadi
hello
I have a situation that don't understand.
I have a regular wire object.
I make a 5 of them. (number of object == 5)
in chop net, I have a wave chop that controls deformations. wave chop 's phase parameter to be unique for each object. I use stamp("../../../autodop..1/geo","OBJID",0) for the phase parameter but this always returns 0.
please help me to solve it.
thank you very much
jellyfish.hipnc
You could try something like this in the Phase chanel
fit01(rand($C),-1, 1)
This creates a random value between -1 and 1 using the channel as random seed.
For this you need to increase the number of channels inside wave_softtrans_clip1 node so you have one for each object.
What your targeting does seem to exist because if you look under the geometry spreadsheet you will see that you have to know the name of the geometry before you can target it. However, there are affectorids one level up that might work.
stamp("op:/obj/AutoDopNetwork","affectorids",0)
I'm not sure if a stamp works inside of chops, however...? Edited by Atom
