How to attract sand to an object?
magneto
Is there a way to attract sand to the surface of another object using distance? If the sand was magnetic, the sand being drawn to the magnetic object based on distance with falloff and not very strong but non continuously moving to the object and sticking to it.
How would you go about achieving this?
  On 12/13/2015 at 2:38 PM, sekow said:
add wind force is neat, as you dont need to battle force getting to big and therefore dont need any drag force. I would not add to v, let the solver calculate that for you.
Good info. I will try wind force vop.
  On 12/13/2015 at 2:43 PM, mestela said:
pop attract doesn't do what you want?
attachicon.gifmagnet_pig.hipnc
I tried it but it wasn't easy to control. I basically want to crawl the sand onto the surface in a tentacle manner. So it will have individual branches of sand moving onto the surface.
I will try pop curve force next with curves shaped like tentacles.
  • 4 years later...
Hi guys,
I have just seen your post and I had a similar doubt on how to create a sand effect.
I am new to 3d, and so I started with Houdini a couple of months ago, I'm trying to understand it slowly. The effect I would like to achieve is this one, basically sand rising and making a shape in that curly way. I hope somebody could explain me what can be used for that as I don't find any tutorials.
Thanks!
va
