View/Inspect userData?
Atom
Hi All,
I have a NULL object that I have added userData to using a python node.
userData does not show up in the geometry spreadsheet because it is not an attribute.
Is there any way to view the user data in the Houdini interface?
You can put your userData content in a string parameter.
Or display it via shelf button or customized right-click menu entry. Here the shelf tool:
def userdata(selected_nodes):
    '''Display user-defined data stored on selected node.'''
    if len(selected_nodes) != 1:
        hou.ui.setStatusMessage('Select one node to use this tool.')
        return
    node = selected_nodes[0]
    data = node.userDataDict()
    data = [(k + ': ' + v) for k, v in data.items()]
    data = '\n'.join(sorted(data))
    msg = 'Displaying user-defined data stored on %s node.' %node.name()
    hou.ui.displayMessage(msg, details=data, details_expanded=True)
userdata(hou.selectedNodes())
It will show newline-separated selectable string:
  • Thanks 1
That is kind of neat. But it makes me think of going back to storing my userData in the text field of a stick note. Then I can see and edit it and if I don't want it anymore I can easily delete it. It looks like userData stores only strings anyway.
