keithlegg Posted January 14, 2005 Share Posted January 14, 2005 Hello all, I am very much a beginner with houdini and I am trying to get a simple scripting problem to work. I wish my first post here wasnt such a simple question but here goes anyway. My question is this. I am trying to write a houdini .cmd script and I want to know the command to insert an expression into a channel. The equivilant of dragging one channel to another and getting the ch("../box1/sizex") , etc only with a script command instead of actually dragging it. From my research my instinct tells me that I should use the chkey function but it does not work in a straitforward manner. suppose i want to link the scalex of box2 to box1. would I not type chkey -f 1 -v 1 -F `ch("../box1/sizeX")` box2/sx why does this not work? what am I missing here? I am hoping for that reassuring green color to tell me the channel is hooked up and nothing I have tried so far will do that. I looked at a lot of other scripts that do it this way and it seems like it should work. Any help would be appreciated. all the other commands in houdini seem to make sense but that damn chkey doesnt act the way I would expect. Also houdini doesnt always return any error message so I dont know where to turn for help. Thanks Keith Quote Link to comment Share on other sites More sharing options...
stevenong Posted January 14, 2005 Share Posted January 14, 2005 Hey Keith, You have to use "chadd" to create the channel first before you can use "chkey". To see how an OPerator is created, perform an "opscript" on it. Open a Textport then opscript /obj/model/foo Cheers! steven Quote Link to comment Share on other sites More sharing options...
keithlegg Posted January 15, 2005 Author Share Posted January 15, 2005 Thank you Steven!!! Now it works. It seems odd to me to add a transform channel when it already has one there. anyway I got it to work. I fancy myself quite the melscripter in maya and its like starting all over again in houdini. One other dumb newbie question and I promise my next one will be a smart question. What the heck is a "chautoscope"?? This is the only command that I dont understand now and there is no help for this. Thanks so much! Keith Quote Link to comment Share on other sites More sharing options...
edward Posted January 15, 2005 Share Posted January 15, 2005 It's syntax is exactly like the chlock command (see "help chlock" in the textport). Except that it doesn't change the "lock" flag on parameters, it changes the "autoscope" flag on parameters. The "autoscope" flag on a parameter says whether a particular parameter will be automatically "scoped" (ie. show up in channel editor, and its keys in the playbar if it has a channel) when the given operator is selected. Instead of just demonstrating how to use that command, let me set things up in H7 while we're at it to make users coming from package XYZ more comfortable. 1. Load a default Houdini session. 2. From the top Desktop menu, choose Animate. 3. The default desktop isn't actually so useful, let's make it look like application XYZ. Close all the panes except for the Viewer and Network Editor. In the Pane menu of the Network Editor, change it to a Channel List pane instead. Just to the left of the menu you just used, there should be this small vertical line button. Click on it to hide the top toolbar of the pane. Now drag the splitter between your two panes more to the right. From the File menu, choose "Save Current Desktop". 4. With your mouse in the Viewer, do Tab > Generators > Geometry. Since it's automatically selected when put down, notice how all its transform parameters have been "scoped" and show up in the Channel List pane. 5. But let's say we don't actually want the Pivot, Scale, or Uniform Scale parameters to autoscope. By default, the Channel List shows the parameter labels (ie. the nice names) instead of the actual parameter token names which we need to know for scripting. With your mouse hovering over the parameters in the channel list pane, press CTRL+right mouse button. This should bring up a menu. Turn off Use Parm Labels. Now it shows the actual parameter token names instead of labels. 6. From the top Windows menu, choose Textport. In the Textport, type this command: chautoscope /obj/geo1 -p* -s* From now on, those parameters in the node /obj/geo1 which either start with the letter p or the letter s will no longer autoscope. We could have explicitly used "px py pz sx sy sz scale" but why do all that extra typing? You can close the textport window now. 7. To see the effect of the chautoscope command, we need to reselect the object. With your mouse in the viewer, hit the s key. This invokes the "favourite" tool which defaults to the Transform tool at the Object level. 8. Click on empty space in the viewer to deselect the object. 9. Click on the geo object to select it again. Notice now that in the Channel List pane, we only have the translate and rotate parameters. Now you can save this hip file and the behaviour will be saved with it. Quote Link to comment Share on other sites More sharing options...
keithlegg Posted January 16, 2005 Author Share Posted January 16, 2005 Thanks Edward! This gives me something to go on... I will hold the questions for now. Many more I am sure. Keith Quote Link to comment Share on other sites More sharing options...
michael Posted January 16, 2005 Share Posted January 16, 2005 wow...ed's in tutorial mode as for: "It seems odd to me to add a transform channel when it already has one there." you don't have a channel - you have a parameter...try 'scoping channels' on a parameter that isn't keyed - you can't Quote Link to comment Share on other sites More sharing options...
edward Posted January 17, 2005 Share Posted January 17, 2005 Yeah, I guess the concept is a bit odd. Think of a channel as what you use when you have a parameter that is animated. The easy way to see whether you have a channel on a parameter is that its background colours changes to some form of green. In Houdini, a channel means that it is animated either via keyframes or an expression. Quote Link to comment Share on other sites More sharing options...
keithlegg Posted January 17, 2005 Author Share Posted January 17, 2005 I am a total beginner with houdini but it seems to me that it follows the paradigm of the old analog synths and patch cords. a "channel" is a flow of data (usually animation or audio from chops?) that hooks to a "parameter" or plug, to change it over time. They are related but not the same thing exactly. The "scoping" is the ability to organize your data and hide the extraneous parameters . In application M , the equivilant thing to autoscope would be "setAttr -e -keyable true " . Again I dont know much about this stuff but I think I get it now. Keith Quote Link to comment Share on other sites More sharing options...
stevenong Posted January 18, 2005 Share Posted January 18, 2005 Hi Keith, IMHO, a channel is a function curve similar to other applications so "chadd" is to "create" the channel(fcurve) & "chkey" is to add keys to the channel(fcurve). Scoping is to display the channel(s) in the Channel Editor where you can edit the slopes, values etc. Cheers! steven Quote Link to comment Share on other sites More sharing options...
