createNode is not working.
cloudfx
Running the python code as OTL (geometry operator type with python)
Its getting this error -->
Traceback (most recent call last):
  File "<console>", line 1, in <module>
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.313/houdini/python2.7libs\houpythonportion.py", line 5
67, in decorator
    return hdefereval.executeInMainThreadWithResult(func, *args, **kwargs)
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.313/houdini/python2.7libs\hdefereval.py", line 41, in
    return _queueDeferred(code, args, kwargs, block=True)
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.313/houdini/python2.7libs\hdefereval.py", line 74, in
_queueDeferred
    raise exc_info[1]
OperationFailed: The attempted operation failed.
This node cannot contain other nodes
Here is the code..
# This code is called when instances of this SOP cook.
node = hou.pwd()
geo = node.geometry()
# create a temporary ROP node
fbx_rop = hou.node('/obj/pyro_import1/OUT').createNode('filmboxfbx')
# set the output path to whereever you want the file to go
fbx_rop.parm('sopoutput').set("$TEMP/out.fbx")
# Path to object hierarchy you want to export
obj_path = hou.node('/obj/pyro_import1/OUT').path()
fbx_rop.parm('startnode').set(obj_path)
# Now just run the "render" method on the node, and delete the ROP
fbx_rop.render()
fbx_rop.destroy()
@symek
Actually, it is not, it has all the point attributes and geo that I want to export..
Understood, but it still might be a Null SOP, albeit:
above line attempts to create a filmboxfbx ROP inside .../OUT node, which doesn't make sense, unless OUT it's a ropnet node. Is it? (your error output suggests it is not).
Assuming filmboxfbx is a ROP type (can't check now, no Houdini around, sorry), you would like to do something like:
geometry_to_export = hou.node("/obj/pyro_import/OUT")
parent = geoemtry_to_export.parent()
ropnet = parent.createNode("ropnet")
ropnet.createNode("filmboxfbx") ...
more or less...
