Viewport Volume Problems
Strooja
Press the D-KEY to bring up the display options and activate the Effects tab. Make sure HDR Rendering is turned on. I had wierd flicker problems on my nVdia 660gtx when this was turned off.
Edited by Atom
I have the same problem. Very annoying.
For me, it snaps back, if I switch between headlight only, and normal lightning, still, it gets difficult to tweak volumes, when you cant really see what you are doing. As the volume turns black, or white as soon as I do anything with it.
  • Like 2
