help understand custom field
Hi guys!
I'm diving into the Pyrosolver node , and under the node ------ Pyrosolver/gasvortexconfinement1,  i found a node --create_curl,  i tweak the parameter Data Name to Forces/curl, but i didnt work ,i can't see the curl field under the Forces container in the spreedsheet . And the default value of the parameter Data Name is MatchField ,  there isn't such a container ,so it create a temp field "curl"  under pyro object .
But i wonder if i can move the filed to a exist container such as Forces.
Thanks.
Thanks Juraj!
The videos are awesome! Thanks for reply!
I did enable Confinement in pyro solver/shape, and could see curl field in spreadsheet , but i wonder if i can move the curl filed to another container , like Forces , which has a Gravity field in it .
in the create_curl node, as i mentioned above, i  set Data Name to Forces/curl , but it didnt work . I'm sorry I didn't explain clearly.
Thanks for your reply, it really helps!
 Peng
