Popular Post OskarSwierad Posted February 1, 2016 Popular Post Share Posted February 1, 2016 (edited) Hi, I ported Hable's tonemapping algorithm, which is popular in video games now (Uncharted, Unity engine), as a VEX COP node It has only one setting - exposure. It's extremely simple to use, yet preserves saturation nicely and leaves non-burnt-out places untouched.The result is... safe. If I needed more dynamic image, I'd correct it later with other nodes. To use it, create a VOP COP2 Filter node in the img (compositing) context. Then open it and pass R,G,B input through the Hable Tonemapping node: EDIT: Added an additional tonemapping algorithm, ACES - used in Unreal Engine 4.8 onwards. ACES gives more pronounced dark tones (even compared to the original photo!) and less desaturated colors than Hable. On the pictures, Hable, original HDR photo and ACES are compared. Both are equally simple to use.Oskar hable_tonemap.hdaFetching info... aces_tonemap.hdaFetching info... Edited March 1, 2016 by OskarSwierad 10 Quote Link to comment Share on other sites More sharing options...
OskarSwierad Posted February 2, 2016 Author Share Posted February 2, 2016 (edited) VEX code: // Hable (Uncharted 2) Tonemapping // // Adapted from code by John Hable // http://filmicgames.com/archives/75 vector hableTonemap(vector x) { float hA = 0.15; float hB = 0.50; float hC = 0.10; float hD = 0.20; float hE = 0.02; float hF = 0.30; return ((x*(hA*x+hC*hB)+hD*hE) / (x*(hA*x+hB)+hD*hF)) - hE/hF; } vector inputColor = set(_R, _G, _; vector tonemapped = hableTonemap(_exposure * inputColor); float hW = 11.2; vector whiteScale = 1.0f / hableTonemap(hW); tonemapped = tonemapped * whiteScale; assign(_R, _G, _B, tonemapped); // ACES Filmic Tone Mapping Curve // // Adapted from code by Krzysztof Narkowicz // https://knarkowicz.wordpress.com/2016/01/06/ // aces-filmic-tone-mapping-curve/ vector ACESFilm( vector x ) { float tA = 2.51f; float tB = 0.03f; float tC = 2.43f; float tD = 0.59f; float tE = 0.14f; return clamp((x*(tA*x+tB))/(x*(tC*x+tD)+tE),0.0,1.0); } vector tonemapped = ACESFilm(set(_R,_G,_ * _exposure); assign(_R, _G, _B, tonemapped); Edited March 1, 2016 by OskarSwierad 2 Quote Link to comment Share on other sites More sharing options...
eetu Posted February 2, 2016 Share Posted February 2, 2016 On 2/1/2016 at 5:56 PM, OskarSwierad said: Please tell me if the file works for you and if you have experience with other algorithms for tonemapping in Houdini. Hey! Good stuff! I did also some other ones at http://forums.odforce.net/topic/8471-eetus-lab/page-14#entry125594if you want to check 'em out.. Quote Link to comment Share on other sites More sharing options...
OskarSwierad Posted February 2, 2016 Author Share Posted February 2, 2016 Whoa, great Somehow I didn't come across your post when I searched for 'houdini tonemapping'. Having found nothing, I decided to write such a node. Quote Link to comment Share on other sites More sharing options...
OskarSwierad Posted March 1, 2016 Author Share Posted March 1, 2016 (edited) I edited the original post with an interesting ACES tonemapping. The pictures compare both algorithms with the original photo. Here are also 1D LUT files (of 1024 length) that perform ACES curve. So you can use it straight in render view Range is 0.001 - 10.0. Still untested but seems to be working. (If used in a Lookup node, it requires 'Quantize' parameter to be set to 'Quantize at this node'. I don't know why.) ACES_LUTs.zipFetching info... Edited March 2, 2016 by OskarSwierad 1 Quote Link to comment Share on other sites More sharing options...
Trnka Posted December 8, 2016 Share Posted December 8, 2016 Hello Oskar, thank you very much for such an interesting thread, may I ask you, which tonemapper do you prefer? And how did you generate these LUTs? Thank you very much Quote Link to comment Share on other sites More sharing options...
OskarSwierad Posted December 19, 2016 Author Share Posted December 19, 2016 (edited) Hi! I prefer ACES for personal projects or early (concept) renders - and Hable or S-Log for previewing work that will be sent further to compositing. I'd like to build some custom tonemappers at some point. Like in "Advanced Techniques and Optimization of HDR Color Pipelines" by Timothy Lottes: http://developer.amd.com/resources/conference-presentations/ I generate LUTs for Houdini with a standalone Python script: # User options: RANGE_MIN = 0.001 # Minimum input pixel brightness () RANGE_MAX = 10.0 # Max input pixel brightness value LENGTH = 1024 # Number of LUT entries (precision) EXPOSURE = 1.0 # Multiplier. Useful range is 0.125 - 8.0. Default is 1.0 OUTPUT_IN_SRGB = False # False means linear TONEMAPPING = 'SLog' # 'ACES', 'Hable' or 'SLog' import math def saturate(value): return max(0.0, min(value, 1.0)) pass def s_log_tonemap(x): # Adapted from "S-Log: A new LUT for digital # production mastering and interchange applications" # https://pro.sony.com/bbsccms/assets/files/mkt/cinema/solutions/slog_manual.pdf result = ((0.432699 * math.log10(x + 0.037584) + 0.616596) + 0.03) return saturate(result) def hable_tonemap_core(x): # Hable (Uncharted 2) Tonemapping # Adapted from code by John Hable # http://filmicgames.com/archives/75 hA = 0.15 hB = 0.50 hC = 0.10 hD = 0.20 hE = 0.02 hF = 0.30 return ((x*(hA*x+hC*hB)+hD*hE) / (x*(hA*x+hB)+hD*hF)) - hE/hF def hable_tonemap(x): tonemapped = hable_tonemap_core(x) hW = 11.2 whiteScale = 1.0 / hable_tonemap_core(hW) return saturate(tonemapped * whiteScale) def aces_tonemap(x): # ACES Filmic Tone Mapping Curve # Adapted from code by Krzysztof Narkowicz # https://knarkowicz.wordpress.com/2016/01/06/ # aces-filmic-tone-mapping-curve/ tA = 2.51 tB = 0.03 tC = 2.43 tD = 0.59 tE = 0.14 result = (x * (tA*x + tB)) / (x * (tC*x + tD) + tE) return saturate(result) def linear_to_gamma_space(x): return pow(x, 1/2.2) pass def gamma_to_linear_space(x): return pow(x, 2.2) pass def encode_linear_to_log(idx): # From Houdini HDK docs, "The Houdini LUT Format": # p = e^(idx * (ln(in_end) - ln(in_start)) / (length-1) + log(in_start)) return pow(math.e, ( idx*( math.log(RANGE_MAX) - math.log(RANGE_MIN) ) / (LENGTH-1) + math.log(RANGE_MIN) )) def calculate_values(): values = [] for idx in range(0, LENGTH): exposureCorrected = EXPOSURE * encode_linear_to_log(idx) result = 0.0 if TONEMAPPING == 'ACES': result = aces_tonemap(exposureCorrected) if OUTPUT_IN_SRGB: result = linear_to_gamma_space(result) elif TONEMAPPING == 'Hable': result = hable_tonemap(exposureCorrected) if OUTPUT_IN_SRGB: result = linear_to_gamma_space(result) elif TONEMAPPING == 'SLog': result = s_log_tonemap(exposureCorrected) if not OUTPUT_IN_SRGB: result = gamma_to_linear_space(result) values.append(result) return values def generate_text(values = []): txt = [ "Version\t\t3", "Format\t\tany", "Type\t\tC", "From\t\t" + str(RANGE_MIN) + " " + str(RANGE_MAX), "To\t\t\t0 1", "Black\t\t0", "White\t\t1", "Length\t\t" + str(LENGTH), "Sampling\tLog", "LUT:", "RGB {" ] for val in values: txt.append("\t" + str(val)) txt[-1] += " }\n" return ("\n").join(txt) Edited December 19, 2016 by OskarSwierad 2 Quote Link to comment Share on other sites More sharing options...
debris Posted January 20, 2017 Share Posted January 20, 2017 I'm just discovering the world of tonemapping etc. and this is an awesome thread with invaluable infos! Thanks!!!! Quote Link to comment Share on other sites More sharing options...
CrazyDraisey Posted May 22, 2017 Share Posted May 22, 2017 (edited) I gave this a whirl in Houdini 16, and it works like a charm. The results of these tonemappers, which I rolled into a single VopCop node so that I can flip between them, are comparable to what I get out of Nuke. Thanks for posting these Oskar! You're a life saver. =] Edited May 22, 2017 by CrazyDraisey Added second image showing the difference that this Aces Vop makes. 1 Quote Link to comment Share on other sites More sharing options...
game hancer Posted February 26, 2018 Share Posted February 26, 2018 On 2/1/2016 at 5:56 PM, OskarSwierad said: Hi everyone I have a question I'm new here I'm looking for hda file? it's luts or something else I'd like to have if it's possible to have them in cube format. or in png format if it's good to thank you all ( aces_tonempa.hda Expand Quote Link to comment Share on other sites More sharing options...
nemsi Posted January 14, 2019 Share Posted January 14, 2019 Could this HDAs work with Redshift? I tested but seems to be too dark to be ok.. Any hint? Quote Link to comment Share on other sites More sharing options...
nemsi Posted January 14, 2019 Share Posted January 14, 2019 Here's a capture.. Quote Link to comment Share on other sites More sharing options...
