pop attract doesn't seem to work. H15 BUG???
Hello Peeps, my first post here. coming from softimage and loving Houdini
Doing some tutorials form http://helloluxx.com/
jump start to Houdini vol 4.
in the tut, we create to source particles one called target the other missle, the target has a pop wind and color.
the missile has a pop attract. but once i go to goal and change the attraction type to "particles" and method type to point per particle, it doesn't work.
tired the same thing in H14 and it worked just fine.
wondering if it is a bug or if it changed in H15.
thanks for your help
cheers
pop attract.hip
There's definitely a bug somewhere there. You can try to deactivate Add ID Attributes on one of your particle source nodes. Don't recall on which, follower or target particles, but I had the same problem. I'm assuming pop attract confuses particle id's and can't distinguish/identify properly follower from target particles.
Edited by Yader
