cwalrus Posted March 15, 2016 Share Posted March 15, 2016 Hi - i can't find the topic where I found this helpful file. What I"m wondering is how to view the colors of the smoke in the viewport and have them match the rendered colors. I suspect it is a Volume Visualization node, but I can't determine what goes where ... I just get mildly colored green blobs, rather than the clearly red, blue, and yellow.... Thanks! Pyro2_Color_Mix.hipnc Quote Link to comment Share on other sites More sharing options...
rbowden Posted March 15, 2016 Share Posted March 15, 2016 (edited) http://forums.odforce.net/topic/16099-mix-pyro-colours/Here is the topic you couldn't find. I downloaded your file and you are right, it is just with the volume visualization sop. Just change the mode (under density ramp) to No Ramp and you should see your colors.Also, when you upload a file with a sim, upload it at frame one so, it doesn't have to cook when you open it up. -Ryan Edited March 15, 2016 by rbowden Quote Link to comment Share on other sites More sharing options...
cwalrus Posted March 15, 2016 Author Share Posted March 15, 2016 Thank you- I had to mess around some more after that and then it worked: put 'density' in the Density field, and 'Cd.*' into the diffuse field Quote Link to comment Share on other sites More sharing options...
