EXR Data Window Planes default value makes no sense?
Why is the EXR Data Window Planes on only for C and A by default? Very often Mantra starts cropping AOVs.
Is this because of performace issues? I think it would be smarter to check all planes by default - no? : )
H15.0.417 has a data window for all planes. Do you have an example file?
I completely turn off the EXR data window because After Effects doesn't understand it. It seems like a moot point if using compression because the extra blank space around the image doesn't add to the file size. Maybe it improves performance for compositing though?
AfterEffects doesn't use the data window correctly. In Nuke it saves an enormous amount of processing time; it keeps things fast!
