dark_cry Posted March 22, 2016 Share Posted March 22, 2016 Hi all, Is there any way to glue active objects to non active deforming object? I tried to update glue position every frame so that it could stick to passive object, but looks like it doesn't work. Attaching hip to be clear Cheers, A glueToDeform.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
rayman Posted March 22, 2016 Share Posted March 22, 2016 Glue won't change positions - it just represents connections between pieces. Use hard constraint instead. You still need to update positions/rotations. 1 Quote Link to comment Share on other sites More sharing options...
Farmfield Posted March 23, 2016 Share Posted March 23, 2016 Here's a great 1h breakdown on using constraints in Houdini from Escape Studios. You'll need to register, but the webinar is free. http://learning.escapestudios.com/player/c/RCQfPcC8ToppF9d/n/ppf5s21i5nqstnx/a/quwpso183vuqdq7 2 Quote Link to comment Share on other sites More sharing options...
dark_cry Posted March 23, 2016 Author Share Posted March 23, 2016 Thanks guys Quote Link to comment Share on other sites More sharing options...
oblong Posted July 20, 2017 Share Posted July 20, 2017 That link does not discuss the issue at all. He does not try to glue an active object to a non active deforming ( or a static ) object. I am re looking into this now myself and surprised to find that there is still no obvious solution and sesi offers no examples. Quote Link to comment Share on other sites More sharing options...
Mzigaib Posted July 20, 2017 Share Posted July 20, 2017 Any updates on this issue? I also would like to know a way to constraint active objects on non active deforming objects. Quote Link to comment Share on other sites More sharing options...
mestela Posted July 20, 2017 Share Posted July 20, 2017 Looking at the original scene, the problem was it was freezing time for all the cubes before creating the constraints. I split off the animated cube from the freeze, and extended the search radius for the connect adjacent pieces, the bottom cube drags the rest and makes them topple over. I put some notes on making constraint networks here: http://www.tokeru.com/cgwiki/index.php?title=ConstraintNetworks glueToDeform_me.hipnc 1 Quote Link to comment Share on other sites More sharing options...
Mzigaib Posted July 21, 2017 Share Posted July 21, 2017 Thanks, I'll take a look on that! Cheers! Quote Link to comment Share on other sites More sharing options...
