amin.khormaei Posted March 30, 2016 Share Posted March 30, 2016 (edited) i wanna make an explosion form particle and the particles has high speed velocity as you can see in the image the particle can not make a trail? what should i do? i set the higher substep i manipulated the motion blur in create density volume node but no proper result please help me BEST REGARDS Edited March 30, 2016 by amin.khormaei Quote Link to comment Share on other sites More sharing options...
kungFu Posted March 30, 2016 Share Posted March 30, 2016 Are you using the single leading particle to create smoke? If you are try emitting particles from the high speed lead particle that are left behind as it moves through space. -js Quote Link to comment Share on other sites More sharing options...
amin.khormaei Posted March 30, 2016 Author Share Posted March 30, 2016 Are you using the single leading particle to create smoke? If you are try emitting particles from the high speed lead particle that are left behind as it moves through space. -js nope , this is just a simple emitter Quote Link to comment Share on other sites More sharing options...
bunker Posted March 30, 2016 Share Posted March 30, 2016 You don't need more than one substep. For particles you can create a small trail using a Trail+Add+Resample sop to create points in-between the previous and current frames. trail_bunker.hipnc 1 Quote Link to comment Share on other sites More sharing options...
