rand(@ptnum)>0.5 ----> Is this possible in blast SOP?
Hey guys, I was wondering if anyone knows how to delete rand points/prims with `rand()` in blast SOP.
For some reason I couldn't get it to work:
`rand(@ptnum)`>0.5
so I did this..
@id>`fit(0.5,0,1,1,npoints(opinputpath(".",0)))`
but I guess there are chases where I dont/cant use id.
Thanks!
you can't do that directly in group parm, but just use wrangle to compute the value as an attribute like:
i@delete = rand(@ptnum)>0.5;
then blast by that attribute:
@delete=1
I remember Blast SOP being faster than removing geometry in VEX
  • Thanks 1
use a point wrangle:
if (rand(@ptnum)>.5)
    removepoint(0,@ptnum);
edit: it'd be interesting to see if the two step approach is faster (flag/blast vs remove in vex)
Edited by fathom
Yes, indeed the blast SOP is faster.
@delete=1
I have been doing the same way so far too. I was just wondering if one step was possible. Thanks for the answer!
Alright, I will do a test to see which one is faster. I ll post the results!
Thanks again!
@delete=1
Yes, just like you said it faster to use blast then removeing geo in VEX, thanks guys.
Almost twice as much: (7M points)
post-10187-0-33605200-1459457907_thumb.j
I think it may depend on how much you're removing from what... I just found that removing primitives in a primitive wrangle was notably faster *if* I was removing a small number of prims from an object with a large number of them (deleting ~20,000 from ~1,000,000)
If I was deleting the majority of them, it was notably faster using Blast (deleting ~980,000 of ~1,000,000)
No idea why!
