border edge query in VEX
I need to find out if an edge is a border edge in VEX. Ive tried reading and researching this for several hours, but am getting nowhere.
I have this geo:
post-7586-0-33760700-1459547048_thumb.jp
I know the point numbers, but thats about it. How can I tell the the edge defined by points 19 and 9 is a border edge, whereas the edge defined by the points 19 and 8 are not?
As I understand it there's no direct way in vex, but you can use neighbourcount(). Obviously if you have faces with 3/4/5 verts, it'll break.
int nc = neighbourcount(0,@ptnum);
if (nc<4) {
  @P.y += 1;
The other way is to use a group to detect unshared edges, but I don't know how well it performs with high polycounts.
Waiting now for Anim to show us how to do it cleanly in vex in 3... 2...   ;)
find_edges.hipnc
Thoose methods sadly don't work. They fail in the example above as line 19, 8 reads as a border edge.
I have to convert edge groups to points when I'm in VEX as far as I can tell, so grouping by border edge is useless in VEX.
I've tried to understand half edges. But it just wont go into my brain! I cant tell if its useful for this.
What I'm trying to do if it helps, is to look at a point, and get vectors pointing towards any other connected point, but only along border edges.
Edited by rich_lord
here is a way with half edges:
current code is for Detail Wrangle, but you can use that function anywhere
int isBorderEdge(int pt0, pt1)
    int hedge = pointhedge(0, pt0, pt1); // try finding hedge
    if (hedge == -1 )
        hedge = pointhedge(0, pt1, pt0);  // try reversed hedge
        if (hedge == -1 ) return -1;  // invalid hedge
    return hedge_equivcount(0, hedge) == 1; // 1 if border edge
int pt0 = 9;
int pt1 = 19;
int isborder = isBorderEdge(pt0, pt1);
printf("Edge %d-%d is%s edge\n", pt0, pt1, isborder == 1 ? " a border" : isborder == -1 ? " not an" : " not a border");
  • Like 3
