meeotch Posted April 2, 2016 Share Posted April 2, 2016 (edited) Can someone fill me in on why the scheme in the attached file doesn't work? Basically, I'm using a wrangle to do some point cloud searching. I want to switch the searched geometry based on some attribute on the wrangle's input geo. The vex for that looks like this: float radius = ch("radius"); int npts = chi("numpts"); int handle; if (@side > 0) { handle = pcopen(@OpInput2,"P",@P,radius,npts); } else { handle = pcopen(@OpInput3,"P",@P,radius,npts); } v@Cd = pcimportbyidxv(handle,"Cd", 0); i@num = pcnumfound(handle); pcclose(handle); I'm guessing that my implementation doesn't play nicely with the way that vex / point clouds parallelize, or something. The result is that half of the points don't find any matched points at all (pcnumfound gives 0). The attached file demonstrates it visually. The code above (node "pc_broke") results in half of the points failing to find matches. If I use the same search geo for both groups (node "pc_works"), then all points find matches. And if I do it in two wrangles, each constrained to one group of points and one search geometry, I get the desired result (node "CORRECT"). Removing the pcclose() has no effect, btw. pc_vex.hip Edited April 2, 2016 by Mitch Deoudes Quote Link to comment Share on other sites More sharing options...
anim Posted April 2, 2016 Share Posted April 2, 2016 I've experienced similar issues with pcopen(), however I'm not really sure what exactly is causing that pcfind() approach seems to work though, so maybe you can use that instead float radius = ch("radius"); int npts = chi("numpts"); int geo = @side > 0 ? 1 : 2; int points[] = pcfind(geo,"P",@P,radius,npts); v@Cd = point(geo, "Cd", points[0]); i@num = len(points); Quote Link to comment Share on other sites More sharing options...
mestela Posted April 2, 2016 Share Posted April 2, 2016 Strange. Tomas's solution is neater of course, but it also works if you open both point clouds, and run your if statement on reading from the 2 open handles instead. float radius = ch("radius"); int npts = chi("numpts"); int h1 = pcopen(1,"P",@P,radius,npts); int h2 = pcopen(2,"P",@P,radius,npts); if (@side > 0) { v@Cd = pcimportbyidxv(h1,"Cd", 0); i@num = pcnumfound(h1); } else { v@Cd = pcimportbyidxv(h2,"Cd", 0); i@num = pcnumfound(h2); } pcclose(h1); pcclose(h2); Quote Link to comment Share on other sites More sharing options...
meeotch Posted April 2, 2016 Author Share Posted April 2, 2016 Interesting - thanks for the replies. Is opening both clouds might be less efficient - or not, because they're "shared" between input points? (This whole thing actually comes from inside a flip sim, which has a bunch of pcfilter()s and other stuff going on - so speed is a concern there, where it isn't in my little demo scene.) Maybe someone with a bigger brain than mine can explain the difference between what's going on behind the scenes with pcfind() vs pcopen()? My gut tells me there's an efficiency / parallelization issue there as well (pcfind doesn't require a matching pcclose, for instance), and possibly the same thing that allows the former to work where the latter fails. Meantime, I'm just doing it with two Wrangles, group-constrained. Which works and probably is efficient, but is a fair amount of duplicated code. Quote Link to comment Share on other sites More sharing options...
f1480187 Posted April 2, 2016 Share Posted April 2, 2016 There are nearpoint() and nearpoints() functions also. int opinput = i@side==1 ? 1 : 2; int pt = nearpoint(opinput, @P, ch("radius")); @Cd = point(opinput, "Cd", pt); Quote Link to comment Share on other sites More sharing options...
Pazuzu Posted April 2, 2016 Share Posted April 2, 2016 (edited) Hi! Just sample the handle inside your condition and all works! float radius = ch("radius"); int npts = chi("numpts"); int handle; if (@side > 0) { handle = pcopen(@OpInput2,"P",@P,radius,npts); v@Cd = pcimportbyidxv(handle,"Cd", 0); i@num = pcnumfound(handle); } else { handle = pcopen(@OpInput3,"P",@P,radius,npts); v@Cd = pcimportbyidxv(handle,"Cd", 0); i@num = pcnumfound(handle); } pcclose(handle); Edited April 2, 2016 by Pazuzu Quote Link to comment Share on other sites More sharing options...
meeotch Posted April 2, 2016 Author Share Posted April 2, 2016 Hmmm... interesting. I wonder why that code needs to be repeated for it to work? There's clearly something I'm missing about how the vex is compiled. Or maybe a bug? Quote Link to comment Share on other sites More sharing options...
anim Posted April 2, 2016 Share Posted April 2, 2016 for a moment it felt like they are sharing oc-tree or something therefore using the same handle for more pointclouds would not work but there is something more to it since following: float radius = ch("radius"); int npts = chi("numpts"); int handle0 = pcopen(@OpInput2,"P",@P,radius,npts); int handle1 = pcopen(@OpInput3,"P",@P,radius,npts); int handles[] = array(handle0, handle1); int i = i@side < 0; int handle = handles[i]; v@Cd = pcimportbyidxv(handle,"Cd", 0); pcclose(handle); has 2 handles in an array called handles[] i contains varying 0 and 1 based on the side, therefore handle = handles contains varying handle from array; and yet pcimportbyidxv(handle,"Cd", 0); returns result from the same handle but still changing single line to: int handle = handles[0]; returns correctly result from that pointcloud and int handle = handles[1]; from another, so the pointcloud handles are both stored in an array correctly and work when accessed directly, but not when accessed through varying variable I'd be really curious what SideFx has to say to that, would be great to understand in detail Quote Link to comment Share on other sites More sharing options...
meeotch Posted April 2, 2016 Author Share Posted April 2, 2016 Yeah - that's exactly the weird gut feeling I was getting about this issue, but couldn't put my finger on. (btw - hi, tomas!) I'll try cross-posting this to the sidefx forum, and see if anyone from sesi chimes in with a more detailed under-the-hood explanation. Quote Link to comment Share on other sites More sharing options...
