Ahmed Saady Posted April 3, 2016 Share Posted April 3, 2016 Hello Guys , Im facing an issue with my workflow from 3dmax to Houdini The problem is from the geometry which it comes from 3dmax so when i import it inside Houdini it comes really big even when i made it in right scale inside 3dmax. I can scale down the scene inside the houdini and fit my camera normally but if i want to make a sim then re export again to 3dmax it will come really small based on what i have before. So how can i solve this issue? Thanks Quote Link to comment Share on other sites More sharing options...
michael Posted April 3, 2016 Share Posted April 3, 2016 the issue is that max uses, I believe, cm as it's units, but Houdini uses meters the best solution for this is to scale down your assets by 0.01 in max - then export to Houdini - do you sim or whatever - and the scale up by 100 - then export back to max. I prefer scaling first - but you could also scale on import. or change your units in max - don't change them in Houdini, you can but it will probably screw things up in DOPs 1 Quote Link to comment Share on other sites More sharing options...
Ahmed Saady Posted April 3, 2016 Author Share Posted April 3, 2016 the issue is that max uses, I believe, cm as it's units, but Houdini uses meters the best solution for this is to scale down your assets by 0.01 in max - then export to Houdini - do you sim or whatever - and the scale up by 100 - then export back to max. I prefer scaling first - but you could also scale on import. or change your units in max - don't change them in Houdini, you can but it will probably screw things up in DOPs Thank you for fast reply well if scale down the file inside 3dmax to 0.01 it will be so small even in Houdini and if i scale it up to 0.1 it will come as a good size there but i tried to export the file as is from Max then scale it down in Houdini to 0.01 then i have to multiply * 1000 so it will retain back to its original size . but as you know the sizes are diffrent from scene to scene so im wondering if there is basic procedural way to fix this issue? Quote Link to comment Share on other sites More sharing options...
bonsak Posted April 3, 2016 Share Posted April 3, 2016 You could make a box in Houdini (it defaults to 1x1x1 m) and export it to max. Then figure out how you have to scale that in Max to match a box in there being 1x1x1m or 100x100x100cm. That will be your scale factor. When exporting from Max to Houdini then just scale your scene on export by the scale factor. It's usually good practise to work in real world units when you're ding any type of simulation in Houdini. -b 1 Quote Link to comment Share on other sites More sharing options...
f1480187 Posted April 4, 2016 Share Posted April 4, 2016 cm/in is also a common factor when dealing with scales. Try 0.0254 first if 0.01 is too small. 1 Quote Link to comment Share on other sites More sharing options...
ahmedsheeraz Posted April 4, 2016 Share Posted April 4, 2016 what i normally do is in max, customize ->units setup-> click system unit setup button -> 1 unit = 1 centimeter, change it to meters...1 optional step is to change the grid box size also by right clicking 3d snap toggle -> home grid and change grid spacing to 1. now export ur model to houdini 1 Quote Link to comment Share on other sites More sharing options...
Ahmed Saady Posted April 4, 2016 Author Share Posted April 4, 2016 Thank you all guys for this great information. I will work on what you explain. Best regards Quote Link to comment Share on other sites More sharing options...
