Arthur Spooner Posted April 10, 2016 Author Share Posted April 10, 2016 I want to control how commands are listed in Hcmd; rather then a long list, to break it up ? Also the first link doesn't display the option with the VCC command ? Quote Link to comment Share on other sites More sharing options...
Arthur Spooner Posted April 10, 2016 Author Share Posted April 10, 2016 (edited) Let me rephrase the first question; as I see it didn't make sense, sorry. Typical Windows commands as used in Windows Shell aka DOS don't work in Hcmd, what commands do I have at my disposal when working with Hcmd, if any, equal to Windows Shell (DOS) ? I can't find any of the VCC commands in this link; http://www.sidefx.com/docs/houdini15.0/ref/utils/ ? Any tried printing the entire page, suppose this page; http://www.sidefx.com/docs/houdini15.0/vex/snippets#arrays? I can only print what is retained within the page and I can't find a way with Chrome or my printer settings to print the entire page ? Edited April 10, 2016 by Arthur Spooner Quote Link to comment Share on other sites More sharing options...
anim Posted April 10, 2016 Share Posted April 10, 2016 Let me rephrase the first question; as I see it didn't make sense, sorry. Typical Windows commands as used in Windows Shell aka DOS don't work in Hcmd, what commands do I have at my disposal when working with Hcmd, if any, equal to Windows Shell (DOS) ? I can't find any of the VCC commands in this link; http://www.sidefx.com/docs/houdini15.0/ref/utils/ ? .. I thought it's classical windows shell with houdini commands included, haven't used it much in Windows I guess for more houdini specific commands you can look into your $HFS/bin folder, where you can see you can use vcc, hkey, and many others that are not listed in that link Quote Link to comment Share on other sites More sharing options...
Arthur Spooner Posted April 11, 2016 Author Share Posted April 11, 2016 (edited) $HFS/bin I don't have a folder within bin called $HFS ? I too was hoping that the houdini commands included would behave identical to the classical windows shell, for example "/w" flag so commands don't get cut off when commands are listed, doesn't work identical to the classical windows command. Edited April 11, 2016 by Arthur Spooner Quote Link to comment Share on other sites More sharing options...
anim Posted April 11, 2016 Share Posted April 11, 2016 well I guess on windows it would be something like %HFS% I guess it's just a path wherever your current houdini is installed Quote Link to comment Share on other sites More sharing options...
Arthur Spooner Posted April 11, 2016 Author Share Posted April 11, 2016 There is no %NFS% folder or path on my system; and I checked almost every folder manually on the system related to Houdini. Quote Link to comment Share on other sites More sharing options...
holycause Posted April 11, 2016 Share Posted April 11, 2016 $HFS is you houdini install dir if your use it from you houdini command shell, it should be set. I don't have my laptop at work to double check it Quote Link to comment Share on other sites More sharing options...
Arthur Spooner Posted April 11, 2016 Author Share Posted April 11, 2016 $HFS is you houdini install dir if your use it from you houdini command shell, it should be set. I don't have my laptop at work to double check it I don't have a $HFS directory within my Houdini installation; I'll wait if you want to verify at work. Quote Link to comment Share on other sites More sharing options...
holycause Posted April 11, 2016 Share Posted April 11, 2016 you dont have a folder called HFS. $HFS points to your install folder ie in windows it will most likely be something like that: C:\program files\sidefx\houdini15.xxx Quote Link to comment Share on other sites More sharing options...
holycause Posted April 11, 2016 Share Posted April 11, 2016 open a textport in houdini and type echo $HFS It will return your houdini dir folder path Quote Link to comment Share on other sites More sharing options...
Arthur Spooner Posted April 11, 2016 Author Share Posted April 11, 2016 There is no HFS folder in my Houdini install directory path in Windows. Quote Link to comment Share on other sites More sharing options...
Arthur Spooner Posted April 11, 2016 Author Share Posted April 11, 2016 If anyone can verify this for me on Windows ? Quote Link to comment Share on other sites More sharing options...
Arthur Spooner Posted April 13, 2016 Author Share Posted April 13, 2016 (edited) Found what I wanted. Edited April 13, 2016 by Arthur Spooner Quote Link to comment Share on other sites More sharing options...
