faxingberlin Posted April 12, 2016 Share Posted April 12, 2016 (edited) I find some examples how to implement houdini's python moudles to general python IDLE.. but hrpyc moudle doesn't work.. but hython works! I want to implement hrpyc modle to python IDLE Importing hou works, but hrpyc doesn't work I try to like this examples link: http://www.sidefx.com/docs/houdini15.0/hom/commandline http://nullege.com/codes/show/src%40h%40o%40HoudiniSublime-HEAD%40HoudiniSublime.py/28/hrpyc/python https://github.com/larsbijl/HoudiniSublime error info: import rpyc.servers.classic_server ImportError: No module named servers.classic_server I try very many times... Changing the paths, and find servers.classic_server ... it doesn't work.. Help me.. please Edited April 13, 2016 by faxingberlin Quote Link to comment Share on other sites More sharing options...
Stalkerx777 Posted April 15, 2016 Share Posted April 15, 2016 Because houdini uses a little bit different version of rpyc, in order to use hrpyc you need to add to sys.path (or PYTHONPATH) the following folders: (On windows) $HFS/python27/lib/site-packages and $HFS/houdini/python2.7libs 1 1 Quote Link to comment Share on other sites More sharing options...
faxingberlin Posted April 21, 2016 Author Share Posted April 21, 2016 On 2016. 4. 15. at 7:21 PM, Stalkerx777 said: Because houdini uses a little bit different version of rpyc, in order to use hrpyc you need to add to sys.path (or PYTHONPATH) the following folders: (On windows) $HFS/python27/lib/site-packages and $HFS/houdini/python2.7libs it works! thank you!.. it doesn't work because I didn't put (import hrpyc) in the enableModule() func... Quote Link to comment Share on other sites More sharing options...
