obj info into chops
Lukich
Hi, there. I have a question. There is an object (a point), animated on the path on the OBJ level. Is there some way to import the transform information of the point from the OBJ level into chops? The only thing that gets physically animated is the position parameter (0-1), which makes the point slide down the curve, but I can't find the transform information for the point itself. Can it be accessed at all?
thanks a lot,
Luka
