Max/Min and Noamlization of Attribute Values?
To get the the maximum value from geometry attributes I've been using a sort SOP. Typically I then plug this into a another sort and reverse so that I can normalize the attribute using Fit Range VOP. This works, but it's a bit cumbersome to set up every time I want to normalize an attribute, which is very frequent.
Is there a better way?
45 minutes ago, ciliath said:
Sky pretty much answered you, there's also the option of using the max and min vop sop nodes for the global max min values.
That would only work if you iterate over all the points, even then it's quite cumbersome. Wouldn't recommend it.
  • 5 years later...
