yjcnbnbnb200 Posted April 25, 2016 Share Posted April 25, 2016 I am new to volume render in Houdini, i have a problem, I have a basic smoke sim, from viewport the simulation looks high detail and very dense, when i use the according smoke import node which has a DOP I/O to render, I found the density is very weak and a lot of detail missing, even the shape is a little bit different, i do not know why. Quote Link to comment Share on other sites More sharing options...
Juraj Posted April 25, 2016 Share Posted April 25, 2016 Hi, maybe it's caused by different visualization densities. Have you changed Smoke Density parameter in your Smoke Object node? If yes, you can add Volume Visualization node with same settings after your DOP I/O node - for viewport visualization. And then in your volume shader you can use the same numbers to achieve similar result to what you see in viewport. Juraj Quote Link to comment Share on other sites More sharing options...
yjcnbnbnb200 Posted April 25, 2016 Author Share Posted April 25, 2016 34 minutes ago, Juraj Tomori said: Hi, maybe it's caused by different visualization densities. Have you changed Smoke Density parameter in your Smoke Object node? If yes, you can add Volume Visualization node with same settings after your DOP I/O node - for viewport visualization. And then in your volume shader you can use the same numbers to achieve similar result to what you see in viewport. Juraj Yes, you are right, but still looks like more detail in viewport and less detail in render. Quote Link to comment Share on other sites More sharing options...
Juraj Posted April 25, 2016 Share Posted April 25, 2016 (edited) Interesting, it should be reversed (more detail in render than in viewport) Are you rendering it with the same lighting as in viewport? Could you post some preview (viewport render and mantra render)? Edited April 25, 2016 by Juraj Tomori Quote Link to comment Share on other sites More sharing options...
yjcnbnbnb200 Posted April 25, 2016 Author Share Posted April 25, 2016 4 minutes ago, Juraj Tomori said: Interesting, it should be reversed (more detail in render than in viewport) Are you rendering it with the same lighting as in viewport? Could you post some preview (viewport render and mantra render)? Ok, i will prepare some after work, btw, I did not apply any shader, no material assigned to this volume, in general it should match at least close to what I saw in viewport right? I mean equal density setting. Quote Link to comment Share on other sites More sharing options...
