Paint SOP - First time
hi,
to use the paint sop, you need uv on your geo.   (*edit* actually it works without the uvs. sorry : /  (since it's painting points))
geo -> uv project -> paint sop
paint sop will colour the POINTS, so it will be dependant of the resolution of you geo.
here a little hip exemple (very basic on a grid)
od_paintSOP.hipnc
Edited by 6ril
Guest tar
Riddle this: render it and then look at you geometry spreadsheet for the Cd values. Hint: the geometry spreadsheet is your number one resource in Houdini to understanding.
Guest tar
18 minutes ago, Arthur Spooner said:
I understand I must override the color ?
Can you show numerically how this would help please. Thanks!
Guest tar
What is the range of values for r,g,b from the colour black to white? Then look at the spreadsheet and see what values the Cd attributes are set to.
Guest tar
No that isn't the correct answer. You seem to be missing elementary computer graphics knowledge, therefore you will be confused by everything. Please google the following:
Tell us what the colour black is in R,G,B values?
Tell us what the colour white is in R,G,B? values?
Guest tar
Correct - now you know this, go back though your questions and see why if the RGB attribute values, when they are over value of 1, which means white, don't show in the viewport.
Guest tar
Well, painting blue works whether you add a shader or not. So looking at the spreadsheet again please read the values of the 'blue' colour.
Guest tar
5 hours ago, Arthur Spooner said:
Blue is 1.0. :unsure:
I'm confused by your confusion. Have you used any computer painting software before? PaintSop works just like Photoshop or MSPaint.
