turas29 Posted May 11, 2016 Share Posted May 11, 2016 Hi guys, i am simulating fire and i want to add embers, and everything is working till I use this technique https://vimeo.com/164518223 to give wind to my fire. If you guys have some time to check i will appreciate it. Thanks fire_embers_problem.hip Quote Link to comment Share on other sites More sharing options...
Jesper Rahlff Posted May 13, 2016 Share Posted May 13, 2016 You are using the Gas Advect node instead of the Gas Advect Field node. In the Gas Match Field node you are creating an empty field, with the Gas Wrangle node you are then binding that field to a value (hint your slider), and then you should Advect that field into your sim, stating that "wind" should be added to velocity of your fire. I have attached your file with the change Cheers fire_embers_problem_solved.hip Quote Link to comment Share on other sites More sharing options...
turas29 Posted May 13, 2016 Author Share Posted May 13, 2016 Thanks Jesper for reply but even when i change it the embers still behave weird, they don't follow my flames. Quote Link to comment Share on other sites More sharing options...
