Vector component in stamp expression
Is it possible to access a single component of a vector in a stamp expression? Or is it just limited to single numbers? I've searched and haven't found anything specific to copy stamping and vectors.
For example, if I had a vector attribute called size and I wanted to just get the second component. I've tried:
stamp('../copy1', 'size.y', 0)
stamp('../copy1', 'sizey', 0)
stamp('../copy1', 'size[1]', 0)
I know it would be easy enough to create an extra attribute with just the second component to stamp instead. But it seems like this should be unnecessary.
You can of course use an Attribute Wrangle to store the single axis in a new attribute and stamp just that.
f@my_y_axis = v@P.y;
Eh, it looks like you reject that solution, hmm...
Edited by Atom
