Scattering asset. Connect/Disconnect Sop inputs and automatically switch between inputs.
Hi guys.
I want to create an asset for copystamping which will allow to connect or disconnect SOP inputs. Would be nice if asset allow to use different input numbers of instance at a time (connect/disconnect necessary objects) and switch between instances.
I can manually create a CopyStamping asset if I have a static number of inputs and if I know a number of input objects which switch operator will use (basic copystamping technic).
I've dug out some info and looks like it's best way to create the asset with a callback scripts. But I'm not familiar with callback scripts and python enough. May be some body can help me with that or have a links for similar solution.
Thank you.
Edited by Anatol
Not that I really wanted but I made this in a bit casual way.
I've merged all objects which I needed for copystamping with "instance.*" , cheked "PackGeometryPrimitives BeforeMerging" and count points number with npoints("../out1"). Now I've got number of objects for copystamping.
WIP
Edited by Anatol
Then I used ForEach SOP for stamping random instanses from MergeSOP onto points.
But still looking for solution with node connections. If some one has an idea, pls.
Edited by Anatol
