how to make fog effect
jangcp
47 minutes ago, Atom said:
Here is a basic animated noise fog volume that might get you started. Play around with the noise settings, box size and resolution of the fog volume.
animated_noise_fog_volume.hipnc
oh thank you so much  Atomic
i saw your hip file and tried make like reference video but i failed...  how can i make like reference video shape and moving...?
can you give me more detail information? please help~ :) i`m sorry to ask over and over... i`m houdini beginner  so i don`t know as well...
ah! and i`m useing houdini 14
Edited by jangcp
You could sculpt your volume in Sops and push that into initial state of a dop simulation. Then you could just use turbulence to really push everything around. You run the risk of running of your fog looking thin in some places though since you aren't pumping more fog in. That is one of many ways you could do it.
If the fog isn't interacting with anything, you could do this all in SOPS and could control all of it using nothing but noise. Atom posted a good example file of that above.
Those are two of many ways you could go about it. While I understand you are a beginner in Houdini, it might be better to look at some of the many tutorials about volumetrics in houdini so you can wrap your head around the subject and at least try something first before coming on the here asking for help.
https://vimeo.com/42988999
https://vimeo.com/user2030228
-Ryan
-Ryan
thank you so much Ryan advice
i found tutorials but i can`t find as well so i asked at here thanks for introduced tutorials for me :)
