tamagochy Posted May 20, 2016 Share Posted May 20, 2016 I made simple fluid sim and i need slow it down. I cached mesh with substeps and get filename like this filemame.numberframe.nambersubstep.ext, but when i load it houdini show me alot sequences not one with substeps. How i can load it? I used hipname.$ff.ext for saving and try to use it for loadind but no luck with it. Quote Link to comment Share on other sites More sharing options...
TheDude Posted May 20, 2016 Share Posted May 20, 2016 So as long as you write out $HIP/test.$FF.bgeo with .5 intervals for example, the file (reading $HIP/test.$FF.bgeo) will pick up all frames as $HIP/test.101.bgeo and all half frames as $HIP/test.101.5.bgeo make sure without integer frame values you are specifically on the .5 frame, and it will be visible just with a $FF in the read Quote Link to comment Share on other sites More sharing options...
