Assigning material to RBD
Abyss
Hi everyone.
I have a trouble assigning material to packed fractured RBD. After dop import I lose all inside and outside groups.
How should I assign material to 'inside' and 'outside' groups in packed RBD ?
4 minutes ago, sadhu said:
Try unpacking after dop import sop by unpack sop. Each packed pieces is represented by a single point, upon unpacking you will have access to inside and outside groups.
Thanks for the help. Spent an hour to solve this.  I realized the DOP import node do it easily by changing the ' Import style ' to 'Fetch the unpacked geometry from DOP network'.
  • Thanks 1
  • 2 years later...
God bless you Abyss for posting the solution to this, you saved me a few hours :-)
