writing to stdout using a python node
Hello
I'm sending alembic rops to hqueue and there's a lot of preroll. Even with alfred-style progress turned on, I have no feedback on what's going on.
I was thinking that I could add a python node to write to the stdout (which I though would show up in the hqueue logs) like so:
     import sys
     f= hou.frame()
     sys.stdout.write('frame: '+str(f) + '\n')
But it doesn't work. Any ideas ?
When I start houdini with the -foreground option (so that the shell it launches from doesn't spawn a new process and should receive outputs) and write to stdout, it only shows up in the python console
Thanks
Hey,
I had the same problem with Tractor. Here's what worked for me in the end (no warranty that it also works with hqueue).
The script is run as a post-frame-script in the alembic rop.
import sys
start = hou.node(".").parm("f1").eval()
end = hou.node(".").parm("f2").eval()
current = hou.frame()
progress = str(int(hou.hmath.fit(current, start, end, 0.0, 100.0))).zfill(3)
print("\rFrame {0} done".format(current))
print("\rALF_PROGRESS {0}%".format(progress))
sys.stdout.flush()
It seems that both the carriage returns AND the flushing are necessary. If any of this is missing I will only get the information in the log when the whole caching process is done.
Hope this helps,
Dennis
Edited by dennis.albus
13 minutes ago, dennis.albus said:
Hey,
import sys
sys.stdout.flush()
Hope this helps,
Dennis
Thanks for the snippet, it actually works in hqueue now, even the simple print, in a python node (instead of the alembic rop which only fires when a frame is written, not during preroll).
My problem was that my python node was after the dopnet which was simulating, so it never fired during preroll. Silly me.
