faxingberlin Posted June 8, 2016 Share Posted June 8, 2016 It's about not just only shaders, so I ask in general Houdini Question. I was studying shaders.. like fractal (mandelbrot) and https://sdm.scad.edu/faculty/mkesson/vsfx319/wip/best_winter2011/ali_jafargholi/project_4.html This is the references(maya works - end of the line final works) I create a fractal vex code in shop level. I want to use the material's color value. It is used as velocity of particles.. When I apply a material shader which I created to a grid, I don't know how to use color(Cf) values(->shader applies to my grid) Is there any way to get Cf value on my grid? Quote Link to comment Share on other sites More sharing options...
kungFu Posted June 10, 2016 Share Posted June 10, 2016 Probably a few ways.... You can use an "attribfrommap" SOP. This works on prims or points. Drop one down and connect it to your geometry, add the file you want to get info from in the Texture Map field. If the geometry had UV's this texture will lay in the same spot as your shader texture. After the attribfrommap SOP the color from the image is now on the geometry. You can use something like a point SOP to attach it to velocity. In a point SOP under the particle SOP "Add Velocity" then use something like @Cd.x @Cd.y @Cd.z to get the color on to the velocity. This isn't going to impart a particular direction to anything, just vary the velocity. velFromColor.hip kf Quote Link to comment Share on other sites More sharing options...
Hamp Posted June 12, 2016 Share Posted June 12, 2016 Is there some way if the object doesn't have UV's? Quote Link to comment Share on other sites More sharing options...
faxingberlin Posted June 12, 2016 Author Share Posted June 12, 2016 On 2016. 6. 11. at 2:44 AM, kungFu said: Probably a few ways.... You can use an "attribfrommap" SOP. This works on prims or points. Drop one down and connect it to your geometry, add the file you want to get info from in the Texture Map field. If the geometry had UV's this texture will lay in the same spot as your shader texture. After the attribfrommap SOP the color from the image is now on the geometry. You can use something like a point SOP to attach it to velocity. In a point SOP under the particle SOP "Add Velocity" then use something like @Cd.x @Cd.y @Cd.z to get the color on to the velocity. This isn't going to impart a particular direction to anything, just vary the velocity. velFromColor.hip kf Thank you. But it's the using pre-maked map.pic. I mean the object applied shop's shader(.vfl code) and extract the Color Value From that. Quote Link to comment Share on other sites More sharing options...
kungFu Posted June 13, 2016 Share Posted June 13, 2016 On 6/12/2016 at 9:51 AM, faxingberlin said: Thank you. But it's the using pre-maked map.pic. I mean the object applied shop's shader(.vfl code) and extract the Color Value From that. If I understand your first question, you want the velocity from a shader. That means you have to calculate (render) the shader to get the color value to transfer it to the grid as velocity. Am I missing something? If it is a series of images you want, then you have to render the series out and put it in the attribfrommap SOP. You could pipe the render into a COP and then reference the COP in the attribfrommap SOP so it updates every frame. Alternatively, you could put the mandelbrot functions onto points, with a point SOP, crank up the resolution and just render that (with color). Why don't you post what you have so far as a file? kf Quote Link to comment Share on other sites More sharing options...
kungFu Posted June 13, 2016 Share Posted June 13, 2016 check this link as well http://forums.odforce.net/topic/10207-3d-mandelbrot-primitive/ cheers, kf Quote Link to comment Share on other sites More sharing options...
faxingberlin Posted June 16, 2016 Author Share Posted June 16, 2016 On 2016. 6. 13. at 11:12 PM, kungFu said: If I understand your first question, you want the velocity from a shader. That means you have to calculate (render) the shader to get the color value to transfer it to the grid as velocity. Am I missing something? If it is a series of images you want, then you have to render the series out and put it in the attribfrommap SOP. You could pipe the render into a COP and then reference the COP in the attribfrommap SOP so it updates every frame. Alternatively, you could put the mandelbrot functions onto points, with a point SOP, crank up the resolution and just render that (with color). Why don't you post what you have so far as a file? kf Thank you for answering. I use Cop and finally I use instance I solve! Thank you! Quote Link to comment Share on other sites More sharing options...
