rendering backward
What if you load an obj you want to render backwards[example - sphere is animated from frame 1 to 24, use timewarp sop(one of the options to load backwards), input range set to 1 to 24 and output range set to 24 to 1] and render it with regular settings ?
  • 4 months later...
use " time warp", eg: the frame range of ur current scene is "1 ~ 120"   , so the input range is 1 , 120. coz u want to render backward, so reverse the frame range, so the output range is "120, 1".
when u play it in the viewpot , it should play backward. and make sure that the frame range of ur render setting is still from " $RFSTART" to "$RFEND".
