petz Posted July 10, 2016 Share Posted July 10, 2016 (edited) On 9.7.2016 at 4:55 PM, Farmfield said: And I have yet to dig deeper into how the extract transforms thingie works that Petz solved it with - I only come so far as to understand it's actually calculating a transform compared to something else. in the file i´ve posted i didn´t actually extract transformations from the thetrahedrons. it´s more about finding the rigid transformation between two geometrys in a least squares sense, or more precisely it´s the method described in this paper LINK. what i ment by "extractTransform" was the existing object node in houdini which uses pretty much the same algorithm under the hood. it´s only available in the obj-context but fairly easy to bring into sops. anyway, both method are used in the uploaded file. hth. petz Edited July 10, 2016 by petz Quote Link to comment Share on other sites More sharing options...
Farmfield Posted July 10, 2016 Share Posted July 10, 2016 Yeah, I managed to figure that out - I think the term is pretty misleading, it really is an alignment more than anything else. Now, still haven't figured out how it's set up - and why. It's about coordinate space, I'm guessing, using the subnets. Need to dig into that more but I've been stuck with other stuff. Quote Link to comment Share on other sites More sharing options...
Butachan Posted August 15, 2016 Share Posted August 15, 2016 (edited) On 7/5/2016 at 6:50 AM, f1480187 said: @Butachan, intrinsics access from Expression functions available from 515 build: prim("../sphere1", 0, "intrinsic:measuredperimeter", 0) Just anted to confirm indeed everything worked fine after I updated! thanks. ...Upps didn't realize the thread had progressed a lot after I checked the file...hehehehe. This solutions are pretty cool by the way. Edited August 15, 2016 by Butachan Quote Link to comment Share on other sites More sharing options...
Farmfield Posted August 15, 2016 Share Posted August 15, 2016 So I just painted myself into a similar corner, trying something similar, reshaping one box to another - and got as stuck as I did with this. I created a thread about it here, if anyone wanna take a look at it. Quote Link to comment Share on other sites More sharing options...
