ch3 Posted June 24, 2016 Share Posted June 24, 2016 I have one cloth object which I have pre-cut in a certain way. I want to have it stitched when the simulation starts but at a given time I want to gradually break the stitches. What kind of constraint can keep two points of the same cloth object together? sbdpinconstraint pins points in space, which I don't want. clothstitchconstraint is meant to work between two different objects right? It kind of works if I set my object to both constraint and goal object, but then how do I create the associations between specific points? Is there something similar to constraintnetwork where I can explicitly specify the constants between points? thank you Quote Link to comment Share on other sites More sharing options...
Atom Posted June 24, 2016 Share Posted June 24, 2016 (edited) I have been exploring stitching cloth in Houdini and created a video on the topic. You can stitch two seams on the same object using the constraint. You just have to make sure your points are in the correct order to prevent cross-stitching. Around 35 minutes into the video I get to the part where I stitch a dart on the same piece of cloth together. Edited June 24, 2016 by Atom Quote Link to comment Share on other sites More sharing options...
zjie Posted May 23, 2019 Share Posted May 23, 2019 (edited) Hi Atom, the video is unavailable, and also is it possible to do stitching over time of the same object in Vellum? Edited May 23, 2019 by zjie Quote Link to comment Share on other sites More sharing options...
