Luijee Posted June 28, 2016 Share Posted June 28, 2016 Hi all, Consider you have a line made from 2 points. You subdivide the line to give you a new point in the middle, how can you add this new point to its own group? As a bonus, how could you group the resulting geo of any SOP? Quote Link to comment Share on other sites More sharing options...
BRZ32 Posted June 28, 2016 Share Posted June 28, 2016 If you group the geometry before the subdivision you can use the combine tab of the group node to group the inverse (not equal =/=) that initial group. That should give you a group with only the new points. Quote Link to comment Share on other sites More sharing options...
Luijee Posted June 29, 2016 Author Share Posted June 29, 2016 18 hours ago, BRZ32 said: If you group the geometry before the subdivision you can use the combine tab of the group node to group the inverse (not equal =/=) that initial group. That should give you a group with only the new points. Inverting the group won't work since the new point created from subdivision inherits the existing group. Is that what you meant? Quote Link to comment Share on other sites More sharing options...
mine Posted June 29, 2016 Share Posted June 29, 2016 Maybe "group transfer" playing with distance threshold? Or maybe if subdivide doesn't change ptnum you can write a wrangle (or a VOP) running it on original geo points to assign points of geo2 into the group based on ptnum? Quote Link to comment Share on other sites More sharing options...
f1480187 Posted June 29, 2016 Share Posted June 29, 2016 @Luijee, it works for me. It doesn't propagate point groups on new points. group_new_points.hipnc Quote Link to comment Share on other sites More sharing options...
3dome Posted June 29, 2016 Share Posted June 29, 2016 creating detail attrib with number of points before subd and grouping after subd based on expression works for me with Houdini Catmull Clark. Tested on simple grid only //detail wrangle i@max = @numpt - 1; //groupSOP @ptnum > @max Quote Link to comment Share on other sites More sharing options...
Luijee Posted June 29, 2016 Author Share Posted June 29, 2016 21 minutes ago, f1480187 said: @Luijee, it works for me. It doesn't propagate point groups on new points. 49 minutes ago, 3dome said: creating detail attrib with number of points before subd and grouping after subd based on expression works for me with Houdini Catmull Clark. Looks like it works for polygon geometry but not for polylines, guess it propagates point groups based on its primitives? I'm taking every odd point in the polyline as it works for what I need, but would be nice if there was a proper reliable method. group_new_points_line.hipnc Quote Link to comment Share on other sites More sharing options...
f1480187 Posted June 29, 2016 Share Posted June 29, 2016 (edited) @Luijee, try Edge Divide node instead of Subdivide. group_new_points_line_edgedivide.hipnc Edited June 29, 2016 by f1480187 Quote Link to comment Share on other sites More sharing options...
Luijee Posted June 29, 2016 Author Share Posted June 29, 2016 Does the job, thanks! Quote Link to comment Share on other sites More sharing options...
