One function, mutiple types of parameters?
Hi!
I want to create dso for custom VEX function, say for the addition of two numbers of various types
Add(number1, number2)
I can create a callback like that
static void
Add(int, void *argv[], void *)
  // Some code
And I think what I can register this function two or more times with different signatures like
new VEX_VexOp("Add@&III", Add); // for integer numbers
new VEX_VexOp("Add@&FFF", Add); // for float numbers
How I can know, what type the input parameters?
Just call appropriate evaluation function
static void
vsocker_Evaluate(int, void *argv[], void *)
   UT_Vector3  *result	= (UT_Vector3 *)argv[0];
   float	*u  = (float *)argv[1];
   float	*v  = (float *)argv[2];
   UT_Vector3  *col1  = (UT_Vector3 *)argv[3];
   UT_Vector3  *col2  = (UT_Vector3 *)argv[4];
   float	*flt  = (float *)argv[5];
static void
fsocker_Evaluate(int, void *argv[], void *)
   float  *result	= (float *)argv[0];
   float  *width  = (float *)argv[3];
   float  *depth  = (float *)argv[4];
static void
vpsocker_Evaluate(int, void *argv[], void *)
   UT_Vector3  *pos  = (UT_Vector3 *)argv[1];
   UT_Vector3  *col1  = (UT_Vector3 *)argv[2];
   UT_Vector3  *col2  = (UT_Vector3 *)argv[3];
   float	*flt  = (float *)argv[4];
static void
fpsocker_Evaluate(int, void *argv[], void *)
   float  *width  = (float *)argv[2];
   float  *depth  = (float *)argv[3];
void
newVEXOp(void *)
	new VEX_VexOp("socker@&VFFVVF",
 	 vsocker_Evaluate,
 	 (VEX_OP_CONTEXT|VEX_SHADING_CONTEXT),
 	 0,
 	 0);
	new VEX_VexOp("socker@&FFFFF",
 	 fsocker_Evaluate,
 	 0,
 	 0);
	new VEX_VexOp("socker@&VVVVF",
 	 vpsocker_Evaluate,
 	 0,
 	 0);
	new VEX_VexOp("socker@&FVFF",
 	 fpsocker_Evaluate,
 	 0,
 	 0);
