expression for get a value at frame number ?
anyone know how can i read a value from a frame number ?
for example in frame 40 and want to access an attribute value at frame 20.
is this possible to do this via expression ?
tnx
Edited by vrman
6 minutes ago, Luijee said:
Use a timeshift node with frame set to 20 then read attributes from that node
no actually i want to use that for each primitive , i found that CHF expression can do this , but the problem is its not working with for each loop ! anyone have this issue ?
