Atom Posted July 12, 2016 Share Posted July 12, 2016 (edited) HI All, I have a BVH file from the CMU collection that I have sourced through the textport window to produce a .CMD and .bclip file. After processing I have a dancing bone rig in my scene. I also have a MakeHuman FBX character that I want to apply the motion to. The problem is that the bone count and names are different. I have tried the trick of using an expression in the rotation fields to try to copy the CHOP animation to the FBX rig but I get terribly twisting and bending as the result. Or no movement at all on some bones because of the naming difference. How do I re-target the mocap data to my custom rig? chop(chsop("../chop")+"/$OS:$CH) ap_BVH_rig.hiplcFetching info... Edited July 12, 2016 by Atom Quote Link to comment Share on other sites More sharing options...
michael Posted July 12, 2016 Share Posted July 12, 2016 unfortunately Houdini has no easy way of re-targeting mo-cap at this time... you can have a look at the file posted here: http://www.sidefx.com/forum/topic/38797/ but if you have a large amount of mocap to process I'd look at MotionBuilder - since it's designed for that kind of work...and I think blender has a re-targeting tool set, Quote Link to comment Share on other sites More sharing options...
